Hi All
I am just getting back in to pc gaming after a very long break and would appreciate any advice on this system.
I am very restricted to budget and out of the loop when it comes to the knowledge of a good component from a bad one.
after some looking around, I can see that pcspecialist is a very good resource. No good looking around places like currys.
My main issue is budget. I can't afford a prime setup and have a budget of around £500.
I have been looking at the Fusion 550 gaming pc from pcspecialist and would appreciate any thoughts on it.
If the components are good to get going and the options are there for effective upgrading when I can afford, would you recommend this system or something else. I want to get started on elite dangerous even though high quality settings won't be possible until a graphics card upgrade, but as long as I can when I'm ready.
http://www.pcspecialist.co.uk/view/Fusion-550-gaming-pc/
Rob
Rob
