Haha co-incidentally I just watched your youtube video on the Ionico - looks like a very nice laptop, any other downsides (other than MUX switch issues?)Should be 115W+15W DB.
Ionico has no Max-Q variants, only Max-P (that's the motto of Tongfang, the ODM).
For instance the Elimina Pro (same manufacturer) with RTX 3060 has the TGP I told you above: 115+15.
I have the Ionico RTX 3070 and it's 125W + 15W DB as per NVIDIA spec of max performance for that part.
(via Control Center you can slide it down a bit if you want less noise, etc.)
