EmmaWilliamson688
Hi guys
So i have a Rog crosshair hero viii wifi board and Asus STILL have not released an update to fix the tpm issue in relation to amd. As a result i contacted pcs and they told me i could disable security device support, which disables tpm. I have ever since not had any lag or stutter (great). Unfortunately this means i cant get windows 11.....Is it worth the update? have i been snaked by taking advice on purchasing this motherboard and processor for my build with PCS?
My concern is Microsoft will soon stop the free upgrade to 11. I dont know how much it costs but i can tell you that the lag/stutter i was getting was infuriating, it even happened when playing youtube videos. Had i known this i probably would have gone intel rather than AMD.
here's my build btw
Send In Your Own Case (corsair ICUE 5000x)
Change to: AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
Change to: ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
Change to: 24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
2TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Change to: 2TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
LED Lighting
50cm UV LED Strip
Change to: NOT REQUIRED
Windows 10 Professional 64 Bit
here's my build btw
LED Lighting
50cm UV LED Strip
