TPM - Changed CPU
BT81
Hi
So, I've changed my CPU (3600x to 5600x)
There is a new Win11 update that has appeared in my settings. I've downloaded the update, gone to install
However, the I can't install as I do not have TPM enabled - I assume it reverted back when I swapped the CPU?
So, into the BIOS I go. Turn TPM to enable, load up the PC and...I am welcome with this message (below)
Now, from my stupidity - I bought the PC from PCs - turned it on and thought nothing of bitlocker, and recently changed the CPU and again never gave bitlocker a thought. Should I - What to do now? :) (Hopefully not swap the CPU back, then back again!)
New CPU installed. fTPM NV corrupted or fTPM NV structure changed.
Press Y to reset fTPM. If you have Bitlocker or encryption enabled, the system will not boot without a recovery key.
Press N to keep previous fTPM record and continue system boot. fTPM will not enable in new CPU, you can swap back to the old CPU to recover TPM related keys and data
Hi
Issue with my TPM - I go into the BIOS, change it to enable, and .....warning comes up about bitlocker etc etc
Any ideas?
What's the issue, do you have bitlocker enabled? It's not very clear what the issue is?
BT81
I will check - I suspect I haven’t - I’ll screen shot what appears on the screen
Agreed - I have been super vague in fairness
BT81
I keep getting this message when I boot up
I suppose the question is - Where do I find the bitlocker key??
