Hi these are the two specs:
Inferno Series: 11.6" Matte HD LED Widescreen (1366x768)
Intel® Core™i7 Quad Core Mobile Processor i7-3610QM (2.30GHz) 6MB
8GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (2 x 4GB)
NVIDIA® GeForce® GT 650M - 2.0GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
500GB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
and the other which I was recommended in my last thread:
Optimus IV
15.6" Matte Full HD 16:9 Widescreen (1900x1080)
Processor (CPU) Intel® Core™i5 Dual Core Mobile Processor i5-3210M (2.40GHz) 3MB
4GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (1 x 4GB)
NVIDIA® GeForce® GTX 660M - 2GB DDR5 Video RAM
Memory - Hard Disk
I will be using it for mid range games and maybe a few higher range (most high end games I play on xbox!), and I will be using it for work at either uni or an apprenticeship. I will be also getting a hd monitor that I maybe connecting it through there, and I may upgrade a few things on both spec later on. I will need to make this least for 3 years or 6 years at the most.
Memory - Hard Disk
Optimus IV
Memory - Hard Disk
