Unused fans etc??
Stu308
Hi , when my build is sent, will any fans ,screws etc that were not used in the build be sent in the package?
The reason I ask is that my case has 1x 140mm fan in front and 1x140mm fan in back. The rear one will be replaced by water radiator fan and would personally put the unused fan in the front where there is space for it. Also normally the motherboard box has lots of accesories what could be used by the user.
Stu.
bigben
Master Poster
All of the accessories will be in the welcome pack. I would guess (don't know for sure) that they will put the fan elsewhere in the case for you or put it in the welcome pack as well.
Stu308
This doesnt tell me anything Fedris. It may change , but it doesn't mean if they take one out they put it back in somewhere else.
Once you place your order email/call PCS to confirm all the fans will be included. I would assume they will be.
