Hi All,
hoping you can give me some advice.
I have the below system and am wanting to upgrade my graphics card.
Two options:
GTX960 - no issues
Or
GTX970 - the configuration says the max power usage will be 455w including a 20% allowance.
- I can't really stretch to both a 970 and a better power supply. Course could afford 960 and power supply but seems pointless!
So my question is whether or not it would be realistic to use a 970 or a bad idea with that power supply? Or is here a half way house/better option between the two?
Not really comfortable with SLI/cross firing as not the most advanced user.
If it helps I have the following plugged in as well drawing power - usb mouse and keyboard, 1tb external hard drive, headset.
Thanks!
Chris
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
ZALMAN Z11 PLUS BLACK MID TOWER CASE
ASUS® P8H61-MX USB3/SI: uATX, USB 3.0, SATA 3.0Gb/s
8GB SAMSUNG DUAL-DDR3 1600MHz (2 X 4GB)
2GB AMD RADEON™ HD7850 - DVI,HDMI,DP - DX® 11, Eyefinity 3 Capable
1st Hard Disk
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON) (£19)
Miscellaneous
FREE BIOSHOCK INFINITE & TOMB RAIDER with AMD 7850/7870 GPUs!
Two options:
GTX960 - no issues
Or
Thanks!
Chris
1st Hard Disk
Miscellaneous
