Hi, hope someone can help, I have the configuration below which has served me very well since October 2022 but I am playing more VR, like many I want high frame rates for my FPS games plus ray tracing and ultra 4K graphics on for my RPG’s. More recently I also want to learn how to use the Starfield Creation Kit and create mods for Starfield. In light of this I need to upgrade my RAM but I’m also considering going all out, spoiling myself, and upgrading the CPU and GPU too.
Q1. My case is on the smaller size and 4090’s seem quite big, will I get the ASUS Tuf OG OC 4090 in my case and still retain enough room for good airflow and cooling. In an ideal world I would upgrade the case to a bigger one but there isn’t an option for that. The GeForce 4090 is a bit smaller but I didn’t see any RGB on the GeForce. In terms of dimensions it will fit but I don’t know if it’s ideal to have less space for air to circulate. I do already have an additional exhaust fan on the back though.
Q2. To get the most bang for buck out of a 4090 I am seeing recommendations for the i9-14900ks. (Intel is my preference), but do these chips put out a lot of heat and will my CPU cooler be enough? There’s 3 different i9-14900 models in the parts picker but I don’t know which would be the best one to use?
Q3. Are there still issues with melting power adaptors for the 4090’s or will my Corsair 1000w psu already be using the right cable to attach to a 4090 directly. If not is a direct cable something that can be requested at the point of requesting the upgrade?
Many thanks in advance for help and advice on this
Current specs and link to re-configure:
Promotional Item
Get Spider-Man Remastered with select GeForce RTX 30 Series GPUs!
Intel® Core™ i5 10-Core Processor i5-12600K (Up to 4.9GHz) 20MB Cache
CORSAIR 1000W RMe SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR iCUE H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
1 x 120mm Thermaltake TOUGHFAN 12 Case Fan
Creative Sound Blaster® Audigy™ FX
Windows 11 Multi-Language Recovery Image - Supplied on USB Drive
Microsoft® Edge
CoolerMaster MS110 Combo Keyboard and Mouse
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/wfVPgeBQxm/
Promotional Item
Microsoft® Edge
