Hi guys, had a quick query in regards to my 3-4 year old PC which I am looking to upgrade but wanted to seek some advice first in terms of what I should go for graphics card wise. I was also going to install a new SSD, wasn't too sure in what else to upgrade? And also, the PC will be used for gaming and other things nothing intensive. But I would like to play modern games at reasonably high settings/fps.
My current spec for my PC is here;
RT 67 Gaming Black
2 x 80mm Quiet Fans
Quiet Xilence 600W 2 x PCI-E 135mm Fan
Intel Core i5 2500, Quad Core (1155, 3.30GHz, 6MB Cache)
Standard Heatsink & CPU Fan
Standard Heatsink Paste
Asus P8H61-M X, 2xDIMM, Max. 16GB, M-ATX
8GB (2 x 4GB) Kingston HyperX 1600MHz DDR3
Silent nVidia 1GB GT 520
500GB SATA II
Noise Dampener For Primary & Secondary HDD
22x Dual Layer DVD +/- Rewriter
Integrated 10/100/1000Mbps
PCI 802.11n 300Mbps Wireless
2 Front + 4 Back Ports
Integrated 7.1 High Definition Channel Audio
27 Inch Asus VE278Q LED Wide, VGA/DVI/HDMI, 10,000,000:1, 2ms
VGA To VGA
Standard Multimedia
Standard Wired Optical
Genuine Windows 7 Home Premium (64bit Version)
Thanks alot!
RT 67 Gaming Black
2 x 80mm Quiet Fans
500GB SATA II
VGA To VGA
Standard Multimedia
Thanks alot!
