Vortex IX Laptop - cannot disable trackpad or turn on control centre
osmanas
Not a dire issue right now as I am using an external keyboard to type to avoid moving the cursor with my palm and am not using the control centre. However, pressing FN+F1/F2 does not disable the trackpad, in fact FN+F2 toggles the LED screen. Pressing FN+ESC does not launch the control centre as my booklet says it would. Is this perhaps a driver problem?
edit: on checking further it appears that control centre does not appear in the windows start menu either. Is there any way I can download it from somewhere?
osmanas
Thanks for the help! Unfortunately, when I try to download the europe drivers as follows:
13312
These are the search functions I'm using to find the drivers, from which I try to download the Control Centre AP Version 1.24:
13313
I have tried downloading others and they give me the same error.
