Welcome to the Water cooling Forum !
DSN
I pushed to get this forum opened due to my up coming build.
For any of you that are interested in giving water cooling a shot ill be posting up video's guides and other information on where to get started, the cost the benefits and the cons.
By all means throw out any questions you might have in the mean time.
DSN
Maintenance for a start, changing out the water every few months, Inspecting the blocks for Oxidisation, checking your connections for and future leeks.
The risk factor. Even using a none conductive solution, pouring it on your parts will never help. If your lucky it wont break them if you spring a leek.
Cost.. A full watercooling setup can cost anywhere from 300/400 minumum.
To list a few :p
DSN
I could put a fish in my PC :p
Not in the loop.. but I could give him his own little res in the dims :p
Fej
Its kinda to do with watercooling, anyone know if the Corsair Hydro H50 cpu coolers any good? my idle temps are running at 42-48 isnt this too hot? My current cpu cooler is the titan fenrir :L
Rakk
The Awesome
Depends entirely on what you've got in your machine as to whether that temperature is ok :)
DSN
As a general rule of thumb, they do not do much better than the high end air coolers.
It also looks like your temps are well within threshold.
If you were looking to overclock there are some very basic single and dual rad setups that will keep her nice and cool.
Fej
What program can i use to control the cpu fan, its running at 100% all the time surely im shortening the lifespan of it :L
Sleinous
Set CPU QFAN Control to ENabled, and either Turbo or Standard profile.
You can do teh same with Case fans too on most motherboards, whether or not they have a PWM connector as this is just for registering temps and helping it auto-adjust. The case-fans will be voltage regulated to slow them down and speed them up, basically like teh CPU cooler.
Grinder
I dont understand why your cpu is at 40+ Celcius at idle with a titan on full tilt sounds like something is wrong to me because you cpu should be below 40 at idle and the titan should be very quiet until you start giving it some stick.
DSN
Case Air flow could be bad. heat of a GFX card in a bad flow case could cause this without to much trouble.
Fej
Well ive sorted my cpu fan issue, but my idle temps vary day to day. Im guessing its just the room temp because some days its idleing at 33-38 and right now its idleing at 44-50. When under full load temps go high as 62
