Basically i need to choose between an AMD or Intel chip. Putting it with a AMD hd7770, i'm guessing should give me a decent level of performance on all current games?
I seem to be swinging more towards the i5-3570k as i don't plan on doing any extreme overclocking (because I don't have the knowledge and don't want to risk it
But my big thing is, the AMD build works out a lot cheaper than the intel build and i don't really just have the money lying around (although i can save up for it). I know the motherboard options on PCS are different with intel/amd which does change the price a little, but still there is around £125 difference out of the two builds.
So ultimately my big question is... Is it worth stretching that extra bit of money for the i5 for future purposes, or should i be looking at a totally different chip compared to the two I have mentioned? And is it better to have a fx-4100 with a better gpu, or an i5 with a mid-range gpu that can be upgraded at a later date?
Thanks for the help, I know you guys reply super fast,
Aaeron
Aaeron
