What would you upgrade on my PC?
Kiazak
Hey guys, I'm looking at upgrading my PC fairly soon, but curious on what to actually do. Out of the pieces below, what would you guys upgrade?
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable (x2 Crossfire Enabled)
mantadog
Superhero Level Poster
Depends what you do with the system, personally it looks quite good to me. Gaming wise perhaps an upgrade to the GPU, but RAM and VCPU should still be coping fine.
Kiazak
Yeah it's for gaming. Any recommendations on gpu's? AMD or nvidia. Not bothered much either way.
mantadog
R9 280X, GTX 770 would both be significant steps up in performance. Really depends how much you want to spend as Keynes said, I assume your PSU will be fine if you have a 6950 in it before though. (best double check it anyway though)
Kiazak
Budget... Would say I can go so far as £400
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU
tom_gr7
Life Serving
Yeah i agree with Manta, keynes and Vanthus. A newer gpu would be your best bet. You will see a massive performance increase going from a AMD 6950 to a Nvidia 770/780.
Kiazak
So worth saving a little more for it then? I like these top tier cards... I've checked with the misses... let the savings commence!
edit: Also will my CORSAIR 850W TX SERIES cut it still?
