Will it work
Oldbitchunter
I really should have checked you guys out first before placing my order. I just hope it's not to late to amend it.
This rig will primarily be used for photo editing using whatever the latest version of Photoshop and Lightroom are. I'll also want to play games like Assetto Corsa Evo, Starfield and any new and upcoming games.
My current monitor is a Dell U2413 which I am unwilling to get rid of because it calibrates perfectly and it's an IPS screen however, I am not adverse to purchasing a more contemporary screen for gaming. Any recommendations regarding a budget screen for gaming will be much appreciated.
I am hoping this will be a quiet build and I was somewhat underwhelmed by the range of component's available to select from. I am not adverse to changing bits around once the beast arrives to get a quiet capable machine. Will it work.
Promotional Item
Get two games and more with purchase of qualifying Intel® products
Promotional Item
Intel® Core™ i7 20-Core Processor i7-14700K (Up to 5.6GHz) 33MB Cache
ASUS® TUF GAMING Z790-PLUS WIFI (LGA1700, DDR5, M.2 PCIe 4.0, Wi-Fi 6E)
32GB Corsair VENGEANCE DDR5 6000MHz CL30 (2 x 16GB)
16GB GIGABYTE RADEON™ RX 7600 XT GAMING OC - 2 x HDMI, 2 x DP
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
2nd M.2 SSD Drive
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
NOT REQUIRED
NZXT Kraken Elite 360 RGB (2024)
ONBOARD LAN PORT
Firefox™
Welcome Book
PCSpecialist Welcome Book
Thank you for your consideration.
Ekans2011
I'd suggest to cancel your order because the INTEL 14th gen is DOA, and even after years of microcode fixes, it's not a good/reliable choice. No one here would recommend it.
Your Dell monitor can be used for photo editing (even if the resolution is really low IMHO), but it's not suitable for gaming purposes because it will bottleneck any modern system (due to the low refresh rate). What is your maximum budget for a proper gaming monitor? What is your maximum budget for a PC?
