Work and Gaming PC
paulof
Hello All,
I've put together an Intel and an AMD system. My friend insists that AMD is the way to go because of the cost but I'm sure about the overall performance and compatibility with the GTX 970 . With the AMD I could upgrade some of the components to fit the budget.
I have an £1800 budget for the machine as I need to get a number of other peripherals. I've always needed laptops before this system.
Uses:
Gaming - FPS on highest quality.
Movies - I have a PS3 that I use to play Blu-Ray, would the PC be better. TV is 3D 1080p.
Work - Certainly running one remotely accessible virtual machine most of the time. Sometimes two with internal networking. Normal office and internet stuff.
I'd like this system to be decently futureproof (upto 4 or 5 years), which is why I've opted for the powerful processor. The Green drive is to be my second backup. The 750W power supply would let me add another graphics card although I'm not sure if that will be necessary.
Intel® Core™i7 Six Core Processor i7-4930K (3.4GHz) 12MB Cache
ASUS® SABERTOOTH X79: SOCKET 2011, R.O.G
16GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (2 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
1st Hard Disk
250GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
3rd Hard Disk
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
CORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£79)
Corsair H60 Hydro Series High Performance CPU Cooler (£59)
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence (£109)
Price: £1,806.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-2011-extreme/vrXgj00YdG/
AMD FX-9590 Eight Core CPU (4.7GHz-5.0GHz/16MB CACHE/AM3+)
ASUS® SABERTOOTH 990FX R2.0 (DDR3, USB3.0, 6Gb/s, CrossFireX/Sli)
16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (2 x 8GB)
1st Hard Disk
3rd Hard Disk
Corsair H100i Hydro Series High Performance CPU Cooler (£89)
Price: £1,439.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-bulldozer-top-spec-pc/Xt_joQcPf9/
The AMD system is not a good choice . An i7-4790 with a cheaper motherboard like the z97-A Asus will be good for your intended use, cheaper than the Intel spec you posted and better than the amd system you have there
paulof
New z97- A Spec and X99 question
Thanks for the reply, Keynes.
I have specced the system you suggest and it would allow me to buy all needed peripherals within the original machine budget.
However, I am surprised that it's possible to put together a similar i7-5930K and X99 system for around £1850. Is there any advantage to starting with the newer chipset?
Intel® Core™i7 Quad Core Processor i7-4790 (3.6GHz) 8MB Cache
ASUS® Z97-A: ATX, USB3.0, SATA 6GB/S, SLi, XFIRE
Free Item
FREE PICK YOUR PATH VOUCHER with GTX 780 / 780Ti /970 / 980 GPUs!
1st Hard Disk
3rd Hard Disk
Price: £1,460.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-pc/bDDo7ufKt4/
The x99 is not worth it for gaming and as you said it is almost £400 more expensive
