Worries about CPU Cooler and PSU!
KrossBowKitty
Hey Guys!
I was browsing some articles on the internet, and got myself a little worried about two things:
1. My CPU running hot.
2. My Desktop running out of juice and parts getting damaged by this.
My hopefully soon to be PC Specs are as follows:
Overclocked CPU
Overclocked Intel® Six Core i7-3930K (3.2GHz @ max 4.6GHz)
ASUS® SABERTOOTH X79: SOCKET 2011, R.O.G
32GB KINGSTON HYPERX BEAST QUAD-DDR3 2400MHz X.M.P (4 x 8GB KIT)
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd DVD/BLU-RAY Drive
4x BLU-RAY ROM DRIVE, 16x DVD ROM
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
Corsair H80i Hydro Series High Performance CPU Cooler
2 x 12CM Black Case Fan
ASUS Xonar DS - Bring Hi-Fi spirit to your Music, Movie & Games
DUAL-BAND WIRELESS 802.11N 450Mbps PCI-E CARD
Genuine Windows 7 Professional 64 Bit w/SP1 - inc DVD & Licence
As you may have seen if you were kind enough to read all that, I'm thinking about a 650Watt Power Supply, however a few factors are making me nervous.
1. I know somebody with very similar specs as that. and they have a 1000Watt PSU.
2. On the config page, when you go into the GPU info, is says that the Radeon 7970 requires a system minimum of 750Watts.
Although the on-board calculator the PC config system has, says the system on load (including a 20% allowance) would use 618Watts.
Not to say I don't trust PC Specialist, its just I would be more comfortable with multiple opinions.
The next thing is the Corsair h80i cooler. I've read many good things about this cooler, although many people whom have a i7 Sandy-Bridge E CPU, use a h100i cooler. Now you're probably thinking, "then why don't you go with the h100i you dumbass!" well I defiantly would if it weren't for the fact that the Cooler Master Storm Enforcer doesn't have enough space, and I have my heart set on that case. However, if you guys say my CPU will run hot on that cooler, then I will reconsider the case I use.
Just incase this will help, I'll be using the PC for video editing, rendering, recording and extreme gaming.
Thank you guys for reading this far! :D
TL;DR
Basically I'm not sure whether the PSU and liquid cooler can handle the specs of this system. Could I get some second opinions please? Thanks :)
KrossBowKitty
You havent ordered the system yet? What are you planning to use it for?
Hey,
I was planning to use it for extreme gaming, video rendering and editing and sometimes recording.
;) (if this comes up twice, sorry but I'm new to this forum layout)
KrossBowKitty
The 7970 has a max power consumption of around 250W,PCS calculate the PSU you need according to the selected components and give a 20% allowance,so you'll be fine going by the configurator.
http://www.hwcompare.com/12508/geforce-gtx-670-vs-radeon-hd-7970/
As you say in your first post the PC is for video editing, rendering, recording and extreme gaming,I would say your spec is pretty good.
Thanks for the feedback Vanthus! :) I think I'll think with the 650Watt PSU then upon reading your advice. Although by saying my spec's pretty good, are you reassuring me that the CPU won't run hot? I would like a second opinion on that if anyone had any knowledge of Liquid Cooling solutions, that would be great :D Thanks
The H80i is a good cpu cooler and if you are purchasing a pre-overclocked system from PCS I wouldn't worry about the cpu overheating. Are you planning in adding a 2nd HD 7970 in the future?
KrossBowKitty
No. I'm happy with just the one monitor (which I'm purchasing on amazon), and the 7970 is more than enough for 1 monitor. I was considering getting 2x7950's, but that exceeded my budget and wasn't really worth it for the type of set up I'm going to be using.
Thanks for the reassurance keynes! Much appreciated! :)
