Would appreciate help building my first custom PC
aaaeron
Hi guys, I was in the process of building a £1100 PC... but due to some family problems I have had to help with, I no longer have that amount of money. I think now i could maybe spare £600 to build a PC with, i know it's not a lot and i would really like to spend more, but unfortunately i can't.
I was wondering if anyone could help configure good spec PC (With a monitor) for around the £600 mark, that will be able to play all the modern games that are out now with decent settings/fps. I don't know if this is possible to do, but if it is I would really appreciate the help, If someone could send me the details of a PC like this (or a print screen) then i would be very thankful. If this isn't possible, i would appreciate any info on how much would i have to spend to get a PC of this required spec AND what spec i would need to look at.
I hope someone will be able to help me with this
And any help will be greatly appreciated.
Thanks a lot for anyone who replies,
Aaaeron
Teaz
Normally in my view, I believe around 650-700 can get you a fair solid build alone without monitor. Thats how i personally reference it. It is normally AMD builds as it is cheaper and bang for buck. Nothing is different between intel or amd. They do exactly the same thing. Intel usually have extra power but their higher price marks that clearly. AMD on the other hand is a little cheaper, a fair price performance ratio so they are bang for buck. Just filling that in if you didnt know.
Here's a balanced build that is ample to play games at decent mid settings or lower with an included monitor for you to consider:
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
AMD A6-3670K APU (2.7GHz, 4 Cores) & AMD Radeon™ HD 6530D Graphics
ASUS® F1A75-M: FM1 A-SERIES, SATA 6.0GB/s, USB 3.0
4GB SAMSUNG DUAL-DDR3 1333MHz (2 X 2GB)
1GB AMD RADEON™ HD6770 - DVI,HDMI,VGA - DX® 11
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE AMD CPU COOLER (£19)
Monitor
18.5" AOC WIDESCREEN LED TFT - 1366 x 768, 5MS, D-Sub, DVI-D (£69)
Total: 597
Configure it here :)
aaaeron
Okay so if i was to save up to £750 you think i would be able to get a pretty good comp with a monitor for the money?
vanthus
Member Resting in Peace
AMD BULLDOZER QUAD CORE FX-4100 (3.60GHz/4MB CACHE/AM3+)
ASUS® M5A97: AM3+ PLATFORM, DUAL DDR3, SATA 6.0GB/s, USB 3.0
2GB AMD RADEON™ HD7850 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Free Item
FREE DIRT SHOWDOWN GAME with any AMD 7000 Series GPU!
Monitor
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
Quantity 1
£743 inc VAT and Delivery.
aaaeron
Thanks a lot for this, it helps being able to see what my options are, how is the FX-4100 in comparison to a 2nd gen I-5?
This looks like a pretty good set up though.
I really do appreciate any help from anyone :)
aaaeron
Is this PC spec good enough for this years games? :)
Thanks to the help i received from the forums on my last post i have looked around and compiled this PC set up. It's total is £700 (inc monitor) and i was just wondering if it will be good enough to play all the games that are coming out in this upcoming year. As always any replies and suggestions on what i should change are really appreciated. Thanks for the help so far, you guys are great!
Case: InWIN BLACK DRAGON RIDER GAMING CASE
Processor (CPU): AMD BULLDOZER QUAD CORE FX-4100 (3.60GHz/4MB CACHE/AM3+)
Motherboard: ASUS® M5A78L-M/USB3: M-ATX, USB 3.0, SATA 3.0Gb/s
Memory (RAM): 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card: 1GB AMD RADEON™ HD7770 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Memory -
1st Hard Disk: 500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
2nd Hard Disk: NONE
RAID: NONE
1st DVD/BLU-RAY Drive: 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader: NONE
Power Supply: 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Processor Cooling: STANDARD AMD CPU COOLER
Fan Controller: NONE
Sound Card: ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities: WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
USB Options: 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Modem: NONE, I WILL BE USING BROADBAND
Floppy Disk Drive: NONE
Firewire: NONE
TV Card: NONE
Operating System: Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Office Software: FREE Microsoft® Office Starter 2010 (Limited functionality Word & Excel)
Anti-Virus: NO ANTI-VIRUS SOFTWARE
Monitor: 21.5" AOC WIDESCREEN LED TFT - 1920 x 1080, 5MS, D-Sub, DVI-D (£89)
2nd Monitor NONE
DVI-D & HDMI Monitor Cables: 1 x 2 METRE DVI-D CABLE (£5)
Eyefinity / GeForce 3D Vision: NONE
Keyboard & Mouse: NONE
Mouse: NONE
Speakers: NONE
Webcam: NONE
Headsets (VOIP): NONE
Surge Protection: NONE
Cable Tidy: NONE
Printer: NONE
External Hard Drive: NONE
Warranty: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
Home Installation: NONE
Data Recovery: NONE
Delivery: STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time: Standard Build - Approximately 10 to 12 working days
Charity Calendar: NONE
Miscellaneous FREE DIRT SHOWDOWN GAME with any AMD 7000 Series GPU!
Pricing Information
Price (excluding VAT) £583.33
Price £700.00
Order Quantity 1
Bulk Discount £0.00
Total Order price (Ex VAT) £583.33
Total Order Price £700.00
