330W charger for a 17.3" Vyper®
danny8518
I'm looking to upgrade my charger from a 220W to 330W as I suspect my machine is drawing more power than can be supplied due to the charger behaving erraticly when I run high spec games.
I checked with the PC Specialist team and they don't have a compatible charger for sale so I was wondering if anyone knows where I could get a compatible charger in the UK?
Thank you,
Thank you,
is this a pcspecialist system? Can you paste your full specs from the order page? PCS wouldn't have sold it with an underpowered charger.
danny8518
Thanks for your quick reply. I think the charger was fine for the laptop, but I do have a number of peripherals, external devices etc installed which I think may be causing the issue.
The spec is:
Promotional Item
Get Death Stranding on PC with select NVIDIA GeForce RTX GPUs!
Vyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
32GB Corsair 2133MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2070 SUPER - 8.0GB GDDR6 Video RAM - DirectX® 12.1
256GB INTEL® 760p M.2 NVMe PCIe SSD (up to 3210MB/sR | 1315MB/sW)
External DVD/BLU-RAY Drive
AC Adaptor
2 x 230W AC Adaptor
2 x 1.5 Metre UK Power Cable (Kettle Lead)
Vyper Series Integrated 91WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
VYPER 17 SERIES RGB BACKLIT UK KEYBOARD
Firefox™
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
Welcome Book
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/vyper-17/V2AZRR9h4z/
The spec is:
So device ports have a set power rating determined by the port. Thats all factored into the PSU rating.
If connecting those devices is causing a power short it’s because there’s a physical problem with the power delivery circuit on the laptop.
Just because you connect a power supply that supplies more wattage has no effect on what the system is going to draw, that’s set by the power supply of the chassis itself. The reason PCS don't stock one is because it doesn't exist.
You’d need an RMA
