Hi
I currently have a fairly old PC with an i7-7700k and GTX 1070. It suits my needs of light 1080p gaming (mostly old games) and office use but I'm looking to upgrade the system because of windows 10 ending support.
I don't really know much about computers so all advice welcomed please. The following spec is with the idea that I keep using the GTX 1070 for the time being, and also that I can upgrade the CPU several years later if need be.
Trying to keep the budget down below £750 (excluding a GPU).
A few specific questions please:
- I'm hoping I will be able to just put the 1070 into the new computer?
- I kept it at the default case because I don't really know what to look for. I expect a more expensive one will be much better so recommendations please?
- I'm not sure what the benefit of the B650 motherboard is compared to the cheaper A620?
- Is 32GB RAM too much?
I also need a new monitor (1080p) - are there are recommendations between the ones offered by PCS?
Thanks!
PCS PRISM II ARGB MID TOWER CASE (PWM)
AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5)
ASUS® PRIME B650-PLUS (AM5, DDR5, PCIe 4.0)
32GB Corsair VENGEANCE DDR5 5600MHz CL40 (2 x 16GB)
1TB CRUCIAL T500 GEN 4 M.2 NVMe PCIe SSD (up to 7300MB/sR, 6800MB/sW)
CORSAIR 750W CX SERIES™ CX-750 POWER SUPPLY
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £679.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/vkJhyR3ZqW/
Thanks!
Microsoft® Edge
