Blackwater Improvements ?
Hood815
If anyone has any other build ideas that would be great ? thanks.
Id like to get a few options before pulling the trigger !
I’ve just seen the 4070ti just been announced ???? should I wait ?
If you can wait, i think it will be exorbitantly expensive, but performance wise it will be good.
Apparently nvidia and AMD are currently being investigated by Europe and the US for price fixing.
Hood815
Oh really :/ I can wait but at the same time i really want my new pc haha !!! just trying to get the best for my buck as they say !
I don't think any of the 4000 series are bang for buck, they're too expensive.
The only ones I would say are worthwhile are the 7900XTX at the moment.
Hood815
CORSAIR iCUE 5000X RGB MID TOWER GAMING CASE Both the 5000D and 5000X are back in the configurator (yay!). This is a great airflow case with lots of RGB goodness; the 5000D is a good alternative if you’re not bothered about flashy lights.
Intel® Core™ i5 14-Core Processor i5-13600K (3.5GHz) 24MB Cache Strong gaming CPU, won’t have any issues at 4K
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP, LHR The prebuilt had a 4080, but it also cut back on a few other areas. The 3080 is still a fantastic card for 4K gaming, and is £500 cheaper than the 4080. The GPU is almost always the first component you’ll upgrade anyway.
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) Fast primary drive for OS and programs.
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) 2tb of fast storage to put lots of games on.
CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET Beefy PSU to handle transient spikes and give you some headroom for upgrades down the line.
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler Powerful cooler to look after your CPU.
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Silver warranty for a fiver is a no brainer.
Price: £2,356.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/z04jcwg3YC/
So I’ve given the link to my wife. I have this feeling she might of changed the graphics card to a 4080 as previously I had said that’s what I wanted. Will the 4080 be okay with this set up ? She’s being very secretive about it and I’m like oh don’t change stuff you don’t understand. 😂 I barely understand it.
sck451
It'll work fine; it's just not good value for money!
MrWilson
As long as she didn't change any other components the PC will be fine and a gaming behemoth. It will blow your £2500 budget though as the 4080 is quite a bit pricier...
Hood815
Quick update for you all. No longer getting a pc at the current time. Had a bit of bad luck and both our cars our out of action and need alot of work. Stupid pot holes.... So ill be back in a couple of months it seems ! Thanks for the help anyway !
sck451
What a pity! But the good news is that there are some new parts coming out in that time and some of them look very tasty, so it might be a blessing in disguise...
I feel for you.
I did a short term contract for the highways agency in one county, they actually had an annual budget set aside to pay out for pot hole damages to rims and bodywork, that budget was actually about double what they paid each year in maintenance on road surfaces.
Go figure, made no sense at all, but us as contractors they wouldn't listen to any sense.
