Checking Media Presence, No Media Found
Madoink
It’s only the drive 1 partitions, drive 0 is your data drive.
If there’s no option to delete them then it does suggest an issue with the drive and that it’s write locked. Very unusual on a Samsung drive.
When I click on them all it says, windows cant be installed on drive
I'm really not confident with taking apart my pc
Don't need to, just remove the drive itself, you don't need to remove anything else.
But it's up to you.
But if you're going to have a custom PC, this is totally standard stuff you're going to have to know how to do regularly. So you may as well start learning now.
If you RMA the drive, they send a replacement next day for you to fit. Takes about 5 minutes to slot in, just like fitting a RAM DIMM.
Then just install windows and you're good to go.
Again, this is total basics. You're going to HAVE to know how to do all this stuff, it will happen regularly.
