if i was to take the graphics card out of one slot & put it in the other slot to try it out. A if that works it means one slot is broken and as i bought machine with the plan to put second card in to run as SLI latter thats no good for me. B if it don't work and it gets sent back HOW do i know tech support not going to say "ahhh you damaged the card when moving it not our fault you have to pay for it". I can guess what you all thinking BUT since i reported this fault over aweek ago i have not been at all happy with the support i have got from tech support and i don't trust them i'm sorry but thats true.
I did when the problem first happen open up the machine and unscrew the screws on card and push it down to make sure it was firm in slot and i did disconnect the power lead running into card and reconnect it to make sure it had not come lose. This was before i rung tech support and i did explane i was not happy to try and do anymore than that as not upto it. Lets be honest if i had the skills i would have just bought parts from somewhere and built machine myself but i don't which is why i bought it from here and took out warrenty for peace of mind.
So worried they will boot machine and say "yes it works" and send it stright back again.
Charges May Apply: Customer has not been notified that a charge may apply. If charges are due, please contact the entrant to discuss whether or not the customer needs to be charged.
I would like to say in defence of PCS,they will fix your machine,even in the unlikely event they have to rebuild it as they did with mine,
at least give them the chance.
I will miss my baby![]()
