Frame Rates Issues
carlos726811
That doesn't make a lot of sense.... Was that while the game was running? Or did you quit the game and take the reading?
Can you play the game and have task manager open and take a screenshot of the game exe's usage of GPU and CPU?
That was while the game was running.. Will do screenshot sometime today. Turned off as was getting fed up with frames dropping lol
I've been reading a few threads, and this is a very common issue, it appears to be driver related with the GPU not taking much load.
NVidia are aware and working on an update:
One of the fixes to try is uninstall the driver again with DDU, the when you reinstall, select the creator driver rather than gamer. Seems to help some people.
@SpyderTracks Could this also be explained if the GPU only has the one PCI-E cable connected? Just wondering if the OP is one of the ones that only had the one cable connected rather than both? Only ask as they are having issues with multiple games. If I am wrong here, then apologies...I don't really understand the 1 vs 2 PCI-E cables and how they affect things
OP did have one cable attached but has corrected that I think.
