Good spec for general use and light gaming?
MK10
With the current GPU, for gaming you wouldn't want anything above 1080p. Considering high hz, the AOC 24G2U would be my recommendation- it's a well reviewed 1080p 144hz gaming monitor and with an IPS panel, the colours should be good for your video editing
With the current GPU, for gaming you wouldn't want anything above 1080p. Considering high hz, the AOC 24G2U would be my recommendation- it's a well reviewed 1080p 144hz gaming monitor and with an IPS panel, the colours should be good for your video editing needs
One final question, is the pre applied thermal paste which comes with the cooler enough or is it safer to apply the MX4 thermal paste?
to apply the MX4 they have to clean all the pre applied paste off before applying the MX4 which can lead to a bad paste job and therefore bad thermals
MK10
Ok thanks, one last question, Windows 10 or Windows 11? I've heard people have faced several problems with Windows 11.
JUNI0R
What Stevey said. I'm still on W10 and have years to swap over- W11 doesn't seem ready so I'm in no rush. If this was your first ever PC then I'd lean towards W11 so you don't need to learn to operating systems, but if you have prior experience, then they're supporting W10 until what, 2024, 2026?
MK10
Hi, can you come up with a PC spec but this time not taking gaming into consideration. I'll be using the PC for a general use such as: university work, programming, building websites, watching movies etc.
What's your maximum budget?
No gaming at all, rudimentary GPU put in place just to accelerate a little. You could probably get away without one at all and use the extra cash to prop up the storage.
Rest of the system is ready for a drop in GPU when you want to though.
Intel® Core™ i5 Six Core Processor i5-12400 (2.5GHz) 18MB Cache
2GB NVIDIA GEFORCE GT 1030 - DVI, HDMI
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
AKASA AK-CC6606BP01 CPU COOLER
Firefox™
Price: £948.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/0Phv9EG!zk/
MK10
AMD Ryzen 9 3900 12 Core CPU (3.1GHz-4.3GHz/70MB CACHE/AM4)
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR, 1600MB/sW)
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
Microsoft® Edge
Price: £1,101.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/jDq4Qd3B2H/
Microsoft® Edge
I'm not sure if you're deliberately trolling here. You seem to be randomly selecting components and posting them up without any feedback on what was previously suggested or insight into why you are making such wild counter suggestions.
If you don't want to take any of the advice being offered then I don't see the point in asking.
The next step is for your thread to be locked as I just don't see the point of this one continuing. Feel free to feed back, but if it's not to actually ask a question or give insight into why you're making the choices then the padlock will be going on.
MK10
Sorry I want a spec which matches the processor that I picked without a graphics card.
MK10
Intel® Core™ i5 10-Core Processor i5-12600KF (3.7GHz) 20MB Cache
ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
4GB NVIDIA GEFORCE GTX 1650 - HDMI
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
Corsair iCUE H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Microsoft® Edge
Price: £1,482.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/XJDbz4Ra3q/
It really depends what software you are using. As much as the 12600k may seem to land in the middle of the pile, it's a very high end CPU and far past what would normally be considered general use. The 12400 would be more "general".
For the gaming it depends on the resolution and what you mean by light. If you're talking 1080p 60fps and medium tier gaming then the 1650 has you covered nicely.
I would save a little on the motherboard and spend a little on the 2nd M2 (it's only £8 for a far better drive).
Microsoft® Edge
Price: £1,430.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/zBwBqJ5h5!/
MK10
Thanks, I've updated it below, any more changes?
Get Monster Hunter: Rise & more with select Intel® Core™ Processors
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR, 1600MB/sW) (Special Offer)
2nd M.2 SSD Drive
Microsoft® Edge
