Help between two specs for a mid-level gaming computer.
Aatrion
Basically, I have put together two specs for a gaming computer I want to buy. Ideally, it should be able to run games like just cause 2 and Red Faction: Guerrilla warfare. I have run into a problem, however, between choosing between the two specs. The first is:
Intel® Core™i5-2400 Quad Core (3.10GHz, 6MB Cache) + HD Graphics
ASUS® P8H67-M LX SI (NEW REV 3.0): M-ATX, USB 2.0, SATA 6.0Gb/s, 2 x PCI
1GB AMD RADEON™ HD6670 - DVI,HDMI,VGA - DX® 11
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
INTEL SOCKET LGA1155/1156 STANDARD CPU COOLER
This one seemed good until I tried making an AMD one which is:
AMD PHENOM II X2 560 (3.30GHz/6MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1GB NVIDIA GEFORCE GTX 560 - DVI,HDMI,VGA - DX® 11, 3D Vision Ready
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
STANDARD AMD CPU COOLER
This one seems too good to be true, as it is better, and much cheaper...
What have I missed out and which should I choose? Also, does anything need changing so I can play skyrim!
Sorry for the long post and any help would be appreciated!
Aatrion
My budget isn't huge, around the £600 mark (although I can go higher if necessary). Both of these cost £595, but one seemed better than the other... Thank you for your reply!
Meds
With a relatively small budget, I'd be tempted to stick to AMD CPUs as they generally offer better value for money. I'd consider the following;
AMD PHENOM II X4 955 (3.20GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Price: £591.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-home-office-pc/
