i had a virus on my pc and managed to get rid of it, though its says now its saying the AIQ51DOR IDE controller is damaged and i cant find anything about.
i guess its the driver but no idea on how to fix it
Processor (CPU) Intel® Core™i7 Processor i7-920 (2.66GHz) 4.8GTs/8MB Cache
Motherboard ASUS® P6T: DDR3, 3-Way SLI & CrossFireX on Demand
Memory (RAM) 6GB CORSAIR XMS3 TRI-DDR3 1333MHz - LIFETIME WARRANTY
Graphics Card 896MB NVIDIA GEFORCE GTX275 PCI EXPRESS
Memory - 1st Hard Disk 500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
1st DVD/BLU-RAY Drive 22x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling 600W Quiet Quad Rail PSU + 120mm Case Fan
Processor Cooling COOLERMASTER V8 EXTREME CPU COOLER - Experience the power o
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT
USB Options 8 x USB 2.0 PORTS (6 REAR + 2 FRONT) AS STANDARD
Modem NONE, I WILL BE USING BROADBAND
Firewire & Video Editing 1 x IEEE 1394a FIREWIRE PORT ONBOARD
Operating System Genuine Windows 7 Home Premium 64 Bit
when i ask it to update the driver it says
WINDOWS WAS UNABLE TO INSTALL YOUR AIQ51DOR IDE CONTROLLER
Window could not find driver software for your divice
If you know the manufacturer of your divice, you can visit its website and check the support section for the drivers software
sorry but no it didnt work
this is what i downloaded
Intel Chipset Inf Update Program V9.1.1.1014 for Windows XP 32bit/XP 64bit/Vista 32bit/Vista 64bit Win7 32bit/64bit
is it the right one?
should i uninstall the damaged driver first? or at least disable it?
sorry im a noob when it comes to this sort of thing :/
are you 100% sure you are clear of any virus/malware.
Yes remove the driver.
Might be a long shot but are there any device on you IDE port? difficult to guess with the age of you system spec whether or not the DVDRW is IDE or SATA.
Im trying to keep a straight face after seeing your pc name lol.
Anyway, I went bk on the asus download section and I found that there is a newer version of the intel storage controller that is NOT under chipset but rather under 'other' here's the link to your mobo again. Please give this driver a whirl. You also need to right click uninstall driver from that IDE controller, its still trying to use an old driver.
w-s-m??? Southampton Bournemouth area. Did you uninstall the ide controller in dev manager first and reboot? I csn try tomorrow if you like, on TV, pm if u want.
