rossbeazley
anyone got updated images for this machine?
It's the same laptop but with the new skylake chips isn't it?
I don't think a simple change to internal options would warrant a name change to Lafité II, would it? It could just be the same but I'd like to know if there are differences.
The new pictures are up now showing the backlit keyboard. However the chassis really does not look that much thinner. (the detailed specs doesn't seem to be updated so it's hard to tell)Just got this email back from PC specialists
Hello,
Thank you for getting in touch, there are a few changes to the chassis but the main one is the 6th Gen chips, the chassis now no longer comes with a LAN port as it is thinner, as such for a LAN connection you would need to purchase a USB 3.0 to LAN adapter from us, also the new Lafite II comes with a backlit keyboard,
If you need anything else, Don’t hesitate to ask,
Many Thanks,
James Dransfield
PC Specialist Support Team
