You either need to do a repaste yourself or raise a ticket for an RMA with PCS if you're not comfortable. That's the first step to make.ok shall hold fire on doing anything else then
I shall ring them tomorrow and also order some thermal paste, i am happy to it myself.You either need to do a repaste yourself or raise a ticket for an RMA with PCS if you're not comfortable. That's the first step to make.
Yeah, it’s very easy to do.I shall ring them tomorrow and also order some thermal paste, i am happy to it myself.
Spoke with PCS this morning.
They dont think there is a heat problem, this chip is designed to run in around this temperature up to 105C apparently.
They do however think there may be a hardware issue with the random game shutting down every now and then so the laptop is going back for diagnostics and repair this week. 3-4 weeks without a laptop![]()
I agree, not overly happy with his response. However they are taking it back for diagnostics etc, so i'd hope someone will understand the problem better there. However, I imagine this is just the start...
I explained everything that has been discussed here, idle temps, peak temps etc.
His response was that the temps are to be expected and if it is over heating there would be MB beeps etc.
Yesterday I wrote a "guide" (it's more of a story). I think it would benefit you to take a look. Here's the link:ok shall hold fire on doing anything else then
Underclocking is not a fix, it's kind of like addressing a scratch by amputating the leg. You're basically completely nerfing the potential performance, may as well have just bought a low end i5.Hi,
So i just got my laptop back from the repair.
here is the comments:
"As previously discussed, we were able to isolate the crashing fault to the GPU. This has now been replaced and this issue has now been resolved.
Additionally, we can also see that when the system is under load it can reach high temperatures. This is due to the limitations of notebook cooling solutions, the system will run hot compared to their desktop counterparts, however, these temperatures are within the safe thermal limits for the components. The manufactures have since confirmed that the chassis' thermal limit is 105 degrees Celsius, and any temperatures below this are within safe usage perimeters."
Thanks for the link above i shall look over it.
On a side note i have "underclocked" my CPU if thats a thing? I have restricted it to 3800 which sees the temps max out at approx. 80C which is much nicer and doesnt seem to cause a noticeable difference in the activities i do on it.
Did you tell them about the resting temperatures?
If I were you, I'd take off the underclock, then measure resting temps and under load and report them. If the resting temperatures are still as high, then the issue isn't resolved.
I couldn't agree more. If it's ok with @Tholan I'd like to highlight this to the site admins after we've done some tests? If it results that the resting temps are still as high as they were then the issue has quite clearly been misunderstood from the outset and misdiagnosed.Totally agree, that's such a poor response from PCS. Would it be possible to request a member of staff chime in on this thread with actual information regarding the laptop? This seems like a complete cop-out to me and I'm really disappointed if that's the case.
It absolutely reeks of not taking the time to understand the actual issue and just jumping to a pre-constructed response.
Did you report that it was 'crashing'? Your problems are overheating so I'm wondering where the PCS technician got the 'crashing' issue (that they 'fixed') from?Hi,
That wasn’t the issue, the high temps will always hit 100c on that chassis with that cpu, and any chassis with that cpu. You HAVE to apply an undervolt to get it within thermal limits, BUT there’s no point applying an undervolt until thermals are within normal ranges. The testing temps on yours showed conclusively that it wasn’t pasted correctly. That needed addressing before doing anything else.Overall the impression and message i get from PCS is that the i9 9900K runs at a hot temperature in comparison to i7. Due to being in a laptop there is not a sufficient method to keep it cool, therefore PCS are happy to have this running at around 95C to 100C.
If this was advertised when i bought it with this information and the fact the fans would sit at 100% constantly i would have gone for a different setup completely.
