Possible Security Threat
PhilGP
Aside from the re-install items, can you tell me if the hacker got control via TeamViewer?
If so, they will have an ID for your PC which will probably be the same ID if you ever re-install TeamViewer again.
I am not 100% certain but I think it gets an ID from the CPU/BIOS.
My father got caught by a hoax caller and handed out his TeamViewer ID. Luckily he didn't get as far as giving the password. But with the defult security settings, there is only a 6 character (lowercase + numeric) password on TeamViewer so not impossible to hack. I changed his TV setting to be a 10 character (upper, lower, digits, symbols) password now and he will need to authenticate any connections. I maintain his PC remotely so I will be the only person connecting.
Sweep695
I can’t remember if it was team viewer exactly but it was a remote connection very similar. I haven’t ever redownloaded I don’t think if so would the best option to uninstall it as I don’t ever need it
Yeah i’ve been connected to the internet during it all. The first blue screen I was repeatedly getting was when I was trying to enter my email for my Microsoft account during the install. Since then I’ve been getting them randomly. Would a complete reset be safe to do now after the clean install incase there are issues with some of the files?
That's a real concern, although since you're using WiFi this could be an issue with the wireless drivers in the installer and your WiFi card. Get a cable and connect your PC to your router via cable for the installation process. You can always go back to WiFi when you've done the install, run Windows Updates, and ensured that all drivers are installed.
Note: Disconnect everything from the PC except keyboard, mouse, and monitor. If your keyboard and/or mouse are wireless then change or recharge the batteries.
Sweep695
Any idea why this would happen when it was working fine before the clean install?
Sweep695
A clean install is just that, it’s not configured, you have to configure windows fully before it will run. That means installing drivers.
Is this something I should be worried about then? I’m currently working from home too on a different device and my WiFi is average at best would it be anything to do with the resources being used on the Wifi
No, the computer isn’t configured yet, so nothing is going to work until it is.
This is totally normal. It’s just how you set up windows. Until it’s configured, you can’t use it.
Before the clean install you were (probably) using the driver designed for your wireless card. When you boot the Windows installer you're using a very basic and generic driver that may not work well with your wireless card - that why using a cable is recommended. :)
Did you go with this in the end?
Sweep695
As dumb as this sounds my PC is on another floor from the router. And I don’t think I have the required cabling to do this. The BSOD are happening every few minutes now. Is there anything else you would suggest? Would it be worth trying the clean install again? I used a USB to do the clean install and booted it using it. I’ve removed it from the PC.
Sweep695
This is the spec here
STANDARD AMD CPU COOLER
Norton 360 Deluxe: 1 User, 5 Devices - 1 Year Subscription
Firefox™
CoolerMaster Devastator III Combo Keyboard and Mouse
This is where you want to go..
Click the + next to Windows 10 64-bit
Download and install the AMD Chipset Drivers
There may be a reboot or 2 required. After which re-run the Windows 10 updates and ensure there are no other updates available.
That should clear the yellow warnings in the Device Manager. If not, there's potentially a hardware issue or a strangely troublesome driver.
Sweep695
Thank you the only issue is I’m not sure I’ll be able to download it as the crashes are happening every few minutes now
Sounds almost temperature related. Are you sure nothing else has been touched? Even something being unseated could cause these issues as temperatures/power increase.
Do you have another system you could access to download to USB pen, or do it on your mobile phone or etc?
Sweep695
I cleaned the filter for the fans the other day is the only hardware related thing I’ve done and it worked fine after that. I don’t have another system I could use unfortunately. What would be the last resort here?
