JughHackman
Ideal spend is £750 absolute maximum of £800. This spec is just under the £800 mark. Is there anything I can do to bring the price down a little without much sacrifice? Any suggestions are welcome. I want to play games on high settings and mostly play MMOs and RPGs like GTA V, Witcher 3 and WoW (hence the 4gb gfx card choice). I also plan to add another graphics card down the road (hence the 650W power supply). I chose the H60 because I have been told that AMD chips like to run hot. Is this correct?
AMD FX-8320 Eight Core CPU (3.50GHz/8MB CACHE/AM3+)
SHARKOON BD28 GAMING CASE (Green LED)
ASUS® M5A99FX PRO R2.0 (DDR3, USB3.0, 6Gb/s,CrossFireX/SLI)
8GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 960 - DVI, HDMI, 3 DP - 3D Vision Ready
1st Hard Disk
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H60 Hydro Series High Performance CPU Cooler
Thanks and toodles!
1st Hard Disk
Thanks and toodles!
