VORTEX III GPU advice
bormom
Hello,
I am considering buying a VORTEX III with a AMD 7970m graphics, and I am wondering if it supports switchable graphics if paired with an i7-3720QM. Not really concerned about how manual the switching process might be.
Many thanks!
Boris
Ub3R_aP3
As far as I know AMD doesn't do something similar to nVidia's Optimus at the moment.
Someone will surely correct me if I'm mistaken though I'm sure :)
In my opinion, if you're buying a laptop with that much power you shouldn't really expect much battery life, you're going for performance afterall. I've read problems with nVidia's Optimus like it doesn't turn the card on for some games/doesn't turn it off at the right time, these are all driver issues however.
bormom
It is more of a noise and heat concern, I don't really plan on using it off the mains. To me a laptop battery is just a UPS, in case I trip the cable or something. It's just, whenI am not gaming, I'd rather have it as quiet and cool as possible. What is the Enduro feature, sounds similar to Optimus?
M3zxu
this feature is present in the gpu itself (called ADM Enduro) but has not been confirmed yet with the clevo lappyes, it should be supported but as there are no official drivers as of now, no one can confirm the situation
bormom
If at least in bios it is possible to disable/enable the adm graphics and use the i7 intel HDx000 , that would still work for me.
