DaelpixPhotos
Super Star
I'm using Afterburner.
I'm on the 15.5 Beta.
The hair on Geralt is already turned off in-game.
It feels like I've been this playing for a while now (but this may not be true as it goes in fits and bursts when I have a spare moment but I must have put 2 hours in at least I would have thought) but I still haven't leveled up once. :
I've been playing for about 8 hours (I'll check that when I get home), and I'm level 5. I can't remember when I got to level 2. Just go to every question mark on the map and do it. I think the first area is all doable at the start (on standard difficulty). Once you get to the second area there is a mix of things you can and can't do at the level you arrive at.
Th GOG starter tells you your playing time total.
There is a lot I haven't got to grips with yet too.
What's the 'second' area exactly? I went to one question mark and it said I didn't have the level to blow it up with a bomb or something so I kind of ignored all question marks from then on thinking there's no point until I got a bit higher. Whoops.
Do the side quests, but you'll gain more XP for doing the main story. The key to leveling up is to keep on fighting things. Keep saving all the time too!
I've just unlocked the quest to reach Skellige, but it's a level 26 quest.....I'm only at level 9.
For everyone looking to make bombs, they're in the alchemy section, you craft them the same way as potions etc and replenish each day you meditate (depending on difficulty)
Guess I need to learn how to make potions too then![]()
Is there a limit to how many times you can meditate in a day? I haven't noticed one. Usable equipped items replenish every time you meditate using up strong alcohol (I haven't run out of that so far).
finished the storyline now and never had an issue!
How long did it take to finish the storyline? Can you continue and do everything else after the storyline?
I have too much stuff in my inventory and I have no idea what to sell !!
