Hi, Any info would be appreciated.
I ordered the Azure system with the Asus Z170A motherboard, now because of the issues with Asus i have changed the board to Gigabyte Z170xp, The thing is i dont particularly like this board but can live with it til it bugs me
I now see these boards are already out of date as Asus has just released 10 new boards as well as other manufacturers. PCS give no other options now in regards to which motherboard you can use for Z170 chipset ( only Gigabyte ).
Right, never having upgraded a motherboard only in a system i will want to wait a bit and purchase a new motherboard and install it using all the parts from the Azure.
What i would like help with is, Do you see any problems i might encounter doing this, Will i need to reinstall windows ? or will windows detect the new Motherboard and ask for drivers etc
Thx for your input guys
Gr4
Gr4
