is my new monitor good ?As i asked earier what resolution & refresh rate is your monitor, the maximum fps you will get is eqivalent to the refresh rate of your monitor
Hz = FPS, so if you have a 60Hz monitor, the max FPS you can achieve is 60FPS.is my new monitor good ?
thankyou very much! So the new monitor i have linked is that really good for gaming?Hz = FPS, so if you have a 60Hz monitor, the max FPS you can achieve is 60FPS.
1080p 60Hz is not a gaming monitor really, it's just a normal display.
For gaming, you really need a 144Hz monitor.
If your new one that is yet to arrive is the 1440p version, then yes that’s okay.is my new monitor good ?
lastly i picked up a new display port lead, will i get the best quality with this cable?If your new one that is yet to arrive is the 1440p version, then yes that’s okay.
If however it’s the 1080p version then no.
as @SpyderTracks says monitor refresh rates and FPS are pretty much read across, however even with a 144hz screen you rarely max it out on full settings. There is a huge amount of marketing rubbish about FPS and things like 240hz screens etc.
To summarise: change your OC back to normal and just enjoy your new screen and games, if you want better performance at a later date go for a 3060ti
The monitor should come with one, no need for a separate one.lastly i picked up a new display port lead, will i get the best quality with this cable?
It's motherboard dependent, that will be for a different motherboard.
